- Thread starter
- #31
palombian
- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Thanks Palombian for contacting me quickly
Now I'm confused
OK - fill the cart via the top hole, no problem
Do you mean that the second hole down which is beside the little board and labyrinth is to be left completely open without any plug after filling?
The Ali site has the following which seems to suggest that (See point B)...
Note
A. Please try to refill inks to 80% of cartridge volume before you install printer;
B. Remove the colors air hole rubbers before plug into the printer
C. When the ink level goes to 10-15%,refill inks again;
D. When you take away the cartridge to refill inks, then plug into printer, the chips has been resetted.
E. Try to choose high quality printing inks;
They confirm the colored plugs are in the air holes and should be removed (but this can be confusing since most refillables use these colored plugs for the ink inlet).
80% seems to be 40 and 80ml. I would not fill less since there will be too much air in the bag and this could harm the correct pressure build up (you can't suck out air as with OEM's).
