Local Ink supplier in Ontario, Canada
Tim2900
I have an small toner cartridge refilling business in Toronto. I buy bulk ink from R-jettek USA. Do you guys know a local bulk ink supplier in Toronto or Ontario? Your help will be appreciated.
johnwarfin
ny.ny
websnail said:
Yes... Mike (Mikling on here) is an image specialists reseller and is based in Toronto... http://www.precisioncolors.com will get you to his AOL site.
I just got off Mikes site and IMO it is very well designed and organized like yours. No music and video baloney. I have a couple questions:
Do your colored caps fit on his 4 oz bottles?
Abd can we assume all Epson dye printers use the same ink?
Yep... I wish he'd get a proper site host other than AOL but that's just the purist in me... If it works... :)
And can we assume all Epson dye printers use the same ink?
You'd have to ask Mike about the neck size on his bottles... Looking at photos it seems that one of the bottles might but I'd be hard pressed to say which, if any.
Re: Epson dye printers and same ink... If the printer uses a Claria ink then it's different from the original Dyebase ink that was used in earlier models. There is a cut off point around the R340 I think but I'm still in the process of compiling my table of compatible models so if you check Epsons site that should give you the necessary clues. Mike has this page which should help:
http://home.eol.ca/~mikling/Epson Ink Outline Page.html
