- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Thanks you.Now I do.
The Pigment Black nozzles that have remained unchanged may be the result of burned out nozzles. They are few enough and spread out that you may never notice them being gone when printing text.
The loss of Magenta may or may work itself out. Since it is seen only in the lighter swath of Magenta, using High Quality setting for printing may hide this loss. If available with your model, consider altering your printing speed to a slower setting when printing photographs in order to decrease stress on the nozzles / electronics (less heat)
Avoid multiple regular cleanings - no more than 2 regular or 1 deep cleaning in 24 hours unless advised otherwise.
It is possible that liquid dish washing liquid, like Dawn or Fairy, di8luted in water may be superior as a soak for print heads as there are enzymes for proteins and plant-based substancess plus surfactants. The longer you soak the better it may work. Patience is key.
