- Jan 18, 2010
- Residing in Wicklow Ireland
FLMK
OK were getting there, so its like this black Dye ink will work perfectly well in the black pigment ink
cartridge and wont leak out that said it wont solve your problem.
Your black ink cartridge is usually fatter than all of the other coloured cartridges ok.
I would tell you NOT to use dye ink in the fatter black cartridge, it wont help.
When you select to print on photo glossy paper your HP printer will not use the ink in
this fatter cartridge no matter what you do, its only used when you print on plain paper.
I reckon the problem you have with the milky image is because the paper that you are using is not HP photo glossy paper.
But when you use the new Image Specialists inks your photos will not be milky but proper black,
because this ink will work better on the Epson/Fuji paper.
I have no explanation for you as to why you were sent two separate black ink; it must have being a mistake, so only use the pigment black.
If there is anything you are still unsure of then keep your questions coming, we are only here to help you get the very best out of your printer.
Patience can be a real help when nothing seems to be going right.
Please let us know how you get on with your new inks..
