How to solve problem Error code 6C10 of Canon Pixma PRO-1
Mr Cuong
Canon Pixma Pro 1
Hi everybody
I have a Canon Pixma Pro 1. When i start up morning it's showed error 6C10.
I turned off and turned on printer severals times, but it's still that.
Please check image attach to know.
Please show me How can i solve this problem?
Thanks all!
The 6C10 error relates to your purge unit, check and see if there is any objects or paper around this unit, try giving it a good splashing of window cleaner and mop up the splashes with paper towel, then flood the unit with window cleaner and turn on the printer again..
The purge unit may also have a blocked waste ink tube, so flooding the unit with window cleaner a second time will clear this blockage..
P.S. This task is not easy, so you may need a flash light..
Mr Cuong
Canon Pixma Pro 1
Dear The Hat,
Thank so much for support!
I turned on printer after 5 das turned off it.
It's run normally, but don't know run long or not.
Have a nice day.
