Hobbicolors now selling PRO-100 Refill Kits.
From the link:
No customization (in-house brewing) thus no compatibility issues . All authentic as manufactured by the manufacturer
Is that a shot at Precision Colors?
Printed photos will remain vibrant and unfaded for many years and will be even longer when kept in photo albums.
That is quite the claim given the accumulated experiences reported in general on the forum for aftermarket inks. Is it true?
You can refill all Canon OEM ink cartridges with or w/o using a chip resetter.
What does a resetter have to do with refilling a cartridge? Nothing.
Why not mention the more critical issue of no reset ink level or continued automatic ink level monitoring?
tjk
Epson 1430
You don't need a resetter? Interesting.
and how many printheads would you need to print all those gallons away ?
Ah ha, yet another ink retailer with grossly outrageous claims, if their inks were that good they wouldn’t have to tell fibs...
Note: there's no mention of the "yellow jello" issue with refilling CLI-42 yellow carts!
The Yellow Gello syndrome still seems too effect some US retailers but it is no longer an issue with the ink formulation used in the EU, and it can be easily mixed with OEM ink.
As far as fading is concerned, ALL dye inks fade with no exceptions, but 3rd party inks fade that bit faster, so Hobbicolor claims of longevity are a load of porkies, however fading can be reduced by using proper paper that complement the ink but it can’t eliminate this problem, it will always remain an issue.
The idea that you can run a Pro 100 successfully without the use of a resetter is pure fantasy, this statement is yet another load of rubbish that is totally erroneous, yes you can disable the ink monitoring but you won’t have your printer working for very long using this method...
how many printheads would you need to print all those gallons away ? :idunno :idunno
If you wish for longevity in your prints, then switch to pigment inks, but not in your Pro 100, acquiring a Pro 10 would be way cheaper than purchasing an endless supply of print heads..
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Yes, I noticed the apparent conflict between the photo (seems to be yellow dye) and the description text (says pigment). I doubt that seller knows WHAT he is selling!
