Hello ...
I was wondering if anyone could give me some information on how to take apart my Canon i860 inkjet printer to get to the purge unit so I can clean it out, as well as some instructions on how to clean it out. Or is there another thread someone can refer me to? I did a search and came up empty.
The problem is that pigment black will not print at all anymore. It's 100% missing. I have spent about the last 2 weeks trying different methods to clean out the printhead, but nothing works. In fact, the problem only got worse. About two weeks ago when I started to try to fix this, I could get a partial pigment black line on a nozzle check as well as a partial page of printed black text. But now I don't even get anything on a nozzle check. I don't think I damaged the nozzles, as the black stopped working all at once and none of the other nozzles are damaged. The photo black, cyan, magenta, and yellow inks are all printing fine.
So I figure it has to be the purge unit underneath the park pad for pigment black? Maybe the black pigment got stuck and dried up there? It's worth a try as I seem to have exhausted all other options.
FYI, here's what I've tried on the printhead so far:
--washing the head with warm water and isopropyl alcohol (2 separate times)
--soaking the head overnight in pure windex
--soaking the head in 100% ammonia for about 6 hours
--soaking the head in 50% bleach and 50% filtered water for about 7 hours
--putting pure windex in an empty pigment black cartridge and then running a deep clean purge and then a nozzle check every night for about a week ... I also put a few drops of windex directly on the park pad before turning off the printer each night
--EEEPROM initiatlization
I guess I should feel lucky that the other colors seem to be OK, and I can use the printer in this limited mode ... but what could cause this stubborn pigment black problem?
Any help would be appreciated. As I said, I don't think it is a printer head problem. I also don't think it is an ink flow problem in the cartridge as I went through a brand new OEM pigment black cartridge doing cleaning cycles and nozzle checks.
Thanks in advance.
Thanks in advance.
