Hi, I've had my Pro9000 II for about 4 months now and have been refilling my OEM cartridges (top fill method) for the last 3 months. With regards to usage I've approximately consumed only 1 set of OEMs, 1 refilled set of UW-8, and 1 refilled set of IS inks (except for the Red and Green which hardly get consumed). I currently have IS inks in the printer.
I haven't used the printer for the last 2 weeks until 3 days ago. I performed a deep clean first, then after printing about 10 sheets of 4"x6" photos I suddenly get banding in the middle of a print job. So I immediately did a deep clean again and printed out a nozzle check pattern, which showed banding in all cartridges except Y and G. Did a deep clean again, DIFFERENT banding pattern, but same cartridges. Clogged heads I thought, so I took the head out for cleaning.
I let running tap water on the ink receptors until the water was clear, then let the head sit on a pool of Windex for about 2 hours, where every 20 minutes I would do a reverse flush using a syringe with a tubing attached to the ink pads. To dry of the head I poured household isopropyl alcohol on the ink pads, then taped a paper towel on the bottom of the print head to wick away fluids in the chambers and let it sit for half a day.
I installed the head back, and the same problem occurs but now only appears on PC, PM, M, C. I couldn't run a head alignment either as the ink clog error comes up. So I thought I didn't clean the head long enough, so I repeat my cleaning process again but now for half a day, and the same half day for the drying process.
So I installed the head back yesterday, did a deep clean, and I still get banding on the PC, PM, M, and C channels. Still couldn't run a head alignment. But one thing I noticed is that the banding pattern was different in between the deep cleans, so it may be a ink starvation issue I thought. So to test this I loaded my spare set of OEM R G B PC PM and UW-8 refilled-OEM C M Y, ran a nozzle chack, and it comes out ok EXCEPT the for the PC which is still banding.
So it's an ink starvation issue I thought, but I can't understand as I'm using an OEM PC cartridge. Anyway, I ran a deep clean, nozzle check shows PC is still banding badly, but less than before. I repeated the deep clean about 4 times, with the PC showing less banding after each nozzle check, but still doesn't disappear. At this point my cartridges went from about 90% full down to 20%, EXCEPT for the OEM PC which went from about 90% to about 80%
So could it be my refilled OEM cartridges are starving the heads? Could my OEM PC cartridge be defective as well? Or is my head damaged and I need to replace it? HELP!
