I wonder if anyone can help me.
I bought a Canon IP6000 printer 9 months ago. I have always used reliable third party ink for refilling my cartridges. My Photo Cyan is now coming out far too strong and is causing a very blue cast over my photos. I think it is this cartridge because when I put the setting to normal print quality the colours are fine and I am assuming that is because it is not using the Photo Cyan cartridge.
I bought a cleaning kit as well and when I put in a blank cartridge in place of the PCyan one the quality becomes much better because it is using the clear Cleaning fluid instead of the photo Cyan ink. I filled up a new empty cartridge with the PCyan after this and the problem with the blue cast comes back. I have tried all the usual maintenance options from the Canon software, "Cleaning", deep head" cleaning etc but no joy.
Can anyone suggest where I go from here?
Here is some advice I got from another forum (photography) but a number of people have recommended me trying here as there are meant to be some great experts here.
This is some advice I got yesterday on the other forum and my replies:
I still cannot resolved the problem:
"First, in normal quality mode, both the photo cyan and photo magenta are not used.
So, if you are not having problems in normal mode, you have narrowed the problem to those two cartridges. But you could be barking up the wrong tree even then, your blue cast could be due to a poorly feeding photo magenta cartridge. Not enough red = blue cast.
If this problem is fairly new and you were having no problem with the same ink before,
you have eliminated the ink as the problem unless the ink has gotten old and has chemically changed. Also missing in your post was anything regarding nozzle checks
which should tell you if you have problem with either your prinhead or in the way a cartridge is feeding.
But my guess is the next step is to examine how your photo magenta cartridge is feeding through the printhead. You may also want to give the nifty stuff forums a try since they cover printhead cleaning in depth.
Its still a guess an my take on the matter given information at hand. But I hope that helps."
"Have you considered the possibility your photo cyan is mislabeled? Grab a white plastic bottle and a couple of Q-Tips. Paint a strip of both on the white plastic. There should be a dramatic difference on white plastic. There is also a difference on paper but it is more subtle."
My reply to these suggestions was:
"Thanks for your speedy replies.
Believe it or not i have not done a nozzle check from the maintenance software. I will do this this evening when I get home.
A good idea about it maybe being the Photo Magenta. I will concentrate on these two and see how I get on. Part of my cleaning kit inncludes a syringe with a flexible plastic nozzle attachment for injecting the cleaning fluid direct into the print head. I had a problem with black earlier this year and that solved the problem. So if the nozzle check does not work I will try this.
I have checked the labeling of the bottle and the cartridge and I refilled them recently and they were ok, so I dont think that is the problem but thanks for the suggestion anyway."
Having checked this out here is the current state of affairs:
OK,
The news is not good,
You were right about it being the Photo Magenta cartridge rather than the PhotoCyan. I ran a nozzle check and there was no printout line for this cartridge (PM).
I uninstalled the Canon software and reinstalled it but no change.
I put a cleaning cartridge in that slot and put back in th PM cartridge and no change.
I did a head cleaning three times and a deep clean and still no change.
Has anyone anymore ideas or am I looking at a new print head or printer?
Kind Regards,
John
OK,
Kind Regards,
John
