ThrillaMozilla
- Jan 18, 2011
If the vacuum is good enough, you will remove the air from the sponge. Without air you can't have foam. That seems to be what gigigogu found. After refilling with his new device the sponge was quite filled with ink. No foam.panos said:Unfortunately foam can be extremely resilient even to a powerful vacuum. In my own syringe vacuum tests, foam was an insolvable problem.ThrillaMozilla said:if you do get bubbles in the sponge, the vacuum should draw the air out and collapse the foam.
Er, Panos, we're talking about foam that might (or might not) be produced with the Freedom Method. The Freedom Method is a vacuum filling method.panos said:That's why I have faith in the freedom method, it produces less foam.
