Does anybody know how to clear this code for this particular printer.
Use the same Button sequence again but if the 2 button procedure doesent work then use 4..yes i have tried this but does not work.
Please explain what you mean by, the computer can’t see the printer, there isn’t anything different than it was before, other than your waste ink is now set to zero, did you turned off the printer after completing all the steps. ?ok it works but now the laptop does not see the printer
If the Service Tool does not connect with your printer, there are only two possibilities why..but the software is not connecting with the printer
What do you specifically mean by "it works"?ok it works but now the laptop does not see the printer
