Jan 5, 2021 #1 I ibo.gezen Newbie to Printing Joined Jan 3, 2021 Messages 6 Reaction score 3 Points 5 Printer Model epson wf c5790 hi.my printer models epson wf pro c5790. my printer has an error called 031004. I guess it's an issue with head temperature. can you help me please. Attachments 11.jpeg 100.1 KB · Views: 1,620
Jan 5, 2021 #2 stratman Printer VIP Platinum Printer Member Joined Apr 19, 2007 Messages 8,706 Reaction score 7,171 Points 393 Location USA Printer Model Canon MB5120, Pencil Please translate to English exactly what the error message says. Not the same printer model as yours but probably applies to your printer as well: Code: 031004, 031005 Description: • Head temperature error (error code: 031004) • X-Hot detect error (at ink replacementtiming) (error code: 031005) Causes: Occurs if the head temperature exceeds a set temperature. • Head FFC inserted slanted • Print head failure Remedy: 1 Check the head FFC connection state Check that the head FFC is not inserted slanted. Y. Replace the print head N. Reassemble From https://printcopy.info/?mod=erc&brand=Epson&model=WorkForce+WF-C869R&page=12 FFC = Flexible Flat Cable http://64.207.244.88/upload/Caution! FFC.pdf
Jan 6, 2021 Thread starter #3 I ibo.gezen Newbie to Printing Joined Jan 3, 2021 Messages 6 Reaction score 3 Points 5 Printer Model epson wf c5790 thank you so much. I'll try the things you suggest carefully.I will share the result with you here. also I did not understand the error message. Only the code is understood.
Jan 6, 2021 #4 stratman Printer VIP Platinum Printer Member Joined Apr 19, 2007 Messages 8,706 Reaction score 7,171 Points 393 Location USA Printer Model Canon MB5120, Pencil You're welcome. Look forward to reading your results.
Jan 9, 2021 Thread starter #5 I ibo.gezen Newbie to Printing Joined Jan 3, 2021 Messages 6 Reaction score 3 Points 5 Printer Model epson wf c5790 hi. I was careless so I plugged the head sockets in the wrong place. problem solved now. thank you very much
Jan 9, 2021 #6 stratman Printer VIP Platinum Printer Member Joined Apr 19, 2007 Messages 8,706 Reaction score 7,171 Points 393 Location USA Printer Model Canon MB5120, Pencil Glad to hear you are back up and running. Happy printing!
