hi
how can i reset waste ink tank counter for epson px660?
thanks
That Epson program will only last a short while and is used to get you out of trouble but you’ll still need to do the reset again properly, but please remember the ink is still building up inside the printer it’s not going to go away regardless of which reset you use, there are no shortcut on reset.i found my answer on my own
no need to buy a key
just google "printer-model adjustment program" i.e "px660 adjustment program"
which is a program that epson service centers use and usally some people who working at epson service center publish them on the web
and for px660 you can download it here: http://www.mediafire.com/download/hhuk7a3j0i961ih/Epson_PX660_Adjustment_Program.rar
You need the "WicReset" program and a reset key. You can get them both through Octoinjet here: http://www.octoink.co.uk/products/WICReset-Key(s).html
Just to gently correct you on this @The Hat , The AdjProg variety of utility will reset the waste counter to zero in the same way as the WICReset tool.That Epson program will only last a short while and is used to get you out of trouble but you’ll still need to do the reset again properly
At least you bother to suggest that I was actually thinking…Just to gently correct you on this @The Hat , The AdjProg variety of utility will reset the waste counter to zero in the same way as the WICReset tool.
I suspect you were thinking of the Epson IPR tools that they release to North American customers. The IPR tools do indeed work the way you suggested with a partial reset (if at all).
 Thank you…
      Thank you…It was a scary place putting myself in your thought processes but I've come out unscathed and perfectly sane...At least you bother to suggest that I was actually thinking…
Thank you…
