The point I was trying to make is that installing a major feature update to the OS is likely to introduce new problems rather than fix the one problem I have.
And OS updates may also resolve certain issues and reason to update the OS.
This is a misleading comparison since
(1) you will have to update eventually.
"O
ne one-hundredth of one percent" deletion issues with updating to Windows 10 1809 is very low risk. Additionally,
(2) since you now know of a potential issue, you can backup your data before updating. Your risk then become zero for loss of that data. You are going to have to update sooner or later so get it done on your terms as much as possible with safeguards implemented.
Also, the link you quoted from is ~1.5 years ago and it is possible MS has improved compatibility with their firewall / OS as
(3) the Microsoft agent hints to check back for a MS update solution to the problem.
For now, we recommend checking this
thread every now and then. Microsoft will provide an update as soon as possible.
The linked thread points back to a link you posted previously. Have you read that entire thread to see if the solution is already released for your version of Windows?
I can't see KB4055038 in my update history.
Have you tried that update?
I fully understand your desire to resolve your issue that obviously has been experienced by others as well. Part of the process in conflict resolution is not only to attempt a settings workaround but also install reasonable updates, especially when a Microsoft "agent" has admitted 1.5 years ago that MS has blame and is looking to resolve the problem with an update.
I don't recall you saying if you tried the firewall changes and static IP workaround in the thread you posted.
If the issue is Windows firewall itself then another consideration is to use a different firewall.
Another consideration is a conflict issue with your AV / malware protection or even a potential infection. A scan with Malwarebytes and your AV software are standard procedure consideration when something bizarre occurs, if only to rule this out as a problem.
