- Thread starter
- #21
- Dec 27, 2014
- Germany
- L805, WF2010, ET8550
I didn't do a direct comparitive test of the L800 vs. the ET-7700 inks, I tested the L800 inks more than two years ago, they performed slightly weaker vs. the Fujiflim DL inks which I'm using since quite a while, when I take the finding that the ET-7700 ink is just slightly better than the DL ink then this most likely would apply as well to the L800 inks - they are most likely not identical but perform similar. There are more factors impacting the actual fading performance - the paper you are using is relevant as well, and I'm getting quite some improvement with a gloss optimizer overprint on a print with dye inks.
You are referrring to b/w prints, the L800/850 are not typical b/w printers with that ink set, are you looking into a special b/w ink set for that purpose, or just want to print b/w prints with the standard setup ? You would need an icm-color profile , but you cannot compensate for changing color temperatures of the viewing light, or you may print with the b/w option in the driver, together with the selection of normal paper or matte paper to force usage of the black ink only. But the ink itself is not completely neutral at different gray shades, and the base color of the paper becomes visible at lighter grays as well. It all depends how critical you are in this respect.
