- Dec 27, 2014
- Location
- Germany
- L805, WF2010, ET8550
a German computer magazine c't recently published a test of some home office printers including the Epson ET-7700 and the new XP-8500. The ET-7700 comes with an Epson CISS and Epson bottled 106 type inks. The XP-8500 is using an Epson Claria HD ink set, 5 colors including a pigmented black for normal paper.
c't is doing a fading test of the inks in use, with an abbreviated daylight test, under a strong Xeon lamp and all UV emissions filtered to resemble an indoor environment behind windows. The target temp is controlled to 20 deg C but no provisions are taken for ozone in the air flow over the target. The exposure time is 100hrs, and color deviations are then measured on several color patches. This test is showing that the Epson inks are better than the Brother and HP inks, and that the ET-7700 dye inks perform slightly better than the Claria inks of the XP-8500. Epson recommended Claria cartridge prices - e.g. cyan are at 11,49€ for 4.1ml or 2800€/litre, market prices are typically 20-30% lower. The ET-7700 bottled ink sells at a distributor price of 10,01€ for 70ml or 145€/l which makes a huge difference. The ET-7700 inks are not called Claria inks , and it is not clear whether they are the same as for the L8xx photo printers but just in a different bottle for an easier handling of the refill process. I'm going to do some testing with these inks in the next time to see how they perform against the Fujifilm DL inks, those genuine Claria inks are just not affordable for me.
