Epson 378 cartridges and resetter question
Cassiop38
Epson, Canon, HP.
Hello, i was wondering if you can reset original Epson 378 cartridges with a cheap resetter from aliexpress or if it only works on one-time-chips OEM empty cartridges that you usually find alongside thems.
i'm aware cartridges shouldn't be empty and, fortunatly, only the Yellow is. I'll also try to refill the cartriges likes PGI-72s, by pooring ink in the absorber. I'll have a try with the Yellow cartridges and some distilled water and report back.
The plan is to use Epson 107 bottles as refiller and use epson original cartridges because the sponge on OEM cartridges doesn't make me feel very safe.
Also if any one of you knows where to get cartridges caps... !
mavtop
Epson XP 15000
the Epson 378 cartridge are Claria HD and the Epson 106 bottles are a good replacement like @Ink stained Fingers fade tests show
Using the 106 bottles you have all the main colors and can mix the main colors to get the light versions, i suspect that someone can help you dosing the colors.
but before you proceed, you have to have an european printer model, to use resetters and to refill the original cartridges, if you are in USA you can't refill the original cartridges and can't use resetters from that i know
Cassiop38
Epson, Canon, HP.
Good to know. I have a european printer which is fitted with almost empty original epson cartridges. i'll probably buy this kit anyway so i have a spare set of cartridges for 10 euros and if something goes wrong with the epson cartridges i won't have to wait too much to get a set.
Aren't 107 bottles Claria HD too ? Agreed that it is more expensive but it is also more convenient.
Thank you very much for your reply.
