- Jan 4, 2012
- Location
- UK
- Canon Pro9000 II
When I started using a ColorMunki Photo profiler, I failed to noticed the setting under (File - Preferences) which selected Version 4 ICC printer profiles as opposed to the alternative, older Version 2.
It wasn't until half a dozen or so profiles had been created and optimised many times with additional images to include many extra colour shades, that I discovered the incompatibility with some software. I tried to compare the visual images of profiles in WinColor.exe. V4 profiles were incompatible.
It wasn't the end of the world, but rather irritating. To have to go through all that profiling and optimisation again didn't appeal.
I searched the Web but could only find a suggestion for X-rite's higher grade software (not ColorMunki Photo), which suggested using saved V4 measurement data to generate a new V2 profile. Saved measurement data is not an immediately available option with ColorMunki Photo software.
However the measurement data must be saved, because you use it, each time you optimise an existing profile with additional images.
So I tried loading an existing version 4 profile and selected the additional image optimisation option. I then selected File - Preferences and V2 under Printer Profiles, this was accepted.
I loaded a new optimisation image and printed the new sheet of patches. I measured the patches and created the new optimised V2 profile. I saved this under a different file name.
This profile is accepted by WinColor.exe and does produce a visual display as a V2 profile.
This relatively simple process appears to allow conversion from V4 to V2 using the existing measurement data, but it is yet to be proved that all the previous profile measurement data is incorporated in the new V2 profile.
It certainly seems to be, the V4 profile size is 2381KB and the new V2 profile size is 2416KB, the increased size should represent the additional data from the new optimisation image.
