- Jan 18, 2010
- Residing in Wicklow Ireland
I think you are getting confused by the term Windows Explorer so let me try to unravel it,
I have not being great at it so far have i, so here goes.
Windows Internet Explorer which you rightly explained is what you use for (Browsing) and so do most guys.
The big BUT follows. The other Windows Explorer is the program that your Windows operating system uses to display
ALL images with-in the Windows picture area i.e. what you see on your screen, two different Applications.
This is Windows Explorer dialogue print preview displayed for Photoshop
Here is another example when you click on Page Setup this time its for Canon
The specify Margins Button is clearly visible
You are also perfectly right in your description of a DLL file,
the software developers do use Windows Explorer to project their images onto you screen by using these very small DLL files (Shortcuts),
they are stored temporarily in Explorer for this very function.
Its like giving someone a flat-pack table to build for you, it get built perfectly
(per instructions) the way you want it without you having to do the work yourself.
On the firmware issue I said I dont fully know how or when these things get up-dated
but I am not going to roll them back to an earlier version and risk making a pigs ear of it
and end up with just a big black ornament, I am stupid to a point.
The USB port switch works by connecting up to four Computers by their USB (A) plug into the back of this port switch (B) plug x four cables,
and only outputs by a single USB (A) plug it's the middle cable that is then connected to a four port USB 2 hub then to three other 4 port USB hubs.
It is described in my Control Panel as a Keyboard and has one functioning key (Scroll-Lock)
so when you want to print you simply hit the scroll lock key twice and all of my printers are then available
to me to use without have to move away from the Computer that I am working at.
The printers are plugged into any of the available plug sockets on my powered USB hubs;
the USB printers that are USB 1 are plugged into a USB 1 hub to avoid confusion and pop-up notices.
I get the same print dialogue box in all of my applications
except "quick print" and "print preview" regardless of which application I use to print from.
That is the picture that I used in post# 17 as an example.
To set the margins in Word it is done on the task bar in (Page Layout) and in the Word pad
if you highlight print preview then in there you can bring up page setup to alter or set your margins.
When I print and set my margins in the printer margins dialogue box I can only use increments above
5 mm for them to take effect despite the fact that it indicates a range from 0 to 30 mm increments.
Since the margins have shifted in my canon printers I just dont bother with them anymore
and just use the default setting of 5mm and leave it at that.
My Canon printers also print Borderless but that does not seem to have be affected by the margin changes,
I think I will have to change to being just a default believer and forget the hymen books..
