- Jan 4, 2012
- Location
- UK
- Canon Pro9000 II
I have read the comments about bronzing on glossy photo paper when using pigment ink and the use of gloss optimizer, over the last month or so.
As I do not have a Canon Pro 9500 II, I thought I didn't have a printer using pigment ink, until I remembered that my old HP PSC 1610 All-in-One Printer Scanner Copier uses pigment black and dye colours. It is currently re-filled with Canon Black [1020P] Pigment ink by IS from Octoinkjet and an OEM HP dye tri-colour cartridge.
So I printed a Word DOC file, which included a multi colour image, 20 lines of black text and two smaller largely black images.
From other posts relating to the use of dye and pigment inks, I believe the images will be printed using the tri-colour dye inks and the text will use the pigment black.
I printed the file on an A4 sheet of my usual micro-porous 280g glossy paper from PPD (which I believe is discounted Ilford paper), claimed to accept pigment as well as dye inks.
I cannot see a trace of bronzing on the text, so what is all the fuss about?? No doubt someone will tell me what I am doing wrong!!
