KnightCrawler
I can't get my refill ink to give me true dark black. It comes out as a horrible dark blue. I test printed the gettyimages test pictures and anything that should be black or gray is blue.
The printer is a Canon IP3000 that does not have the memory chips on them. I wanted to try the older Canon high resolution ink since I had so much of it and at first it seemed to work ok but as soon as it needs gray or black I get blue instead.ghwellsjr said:Assuming that you have a Canon printer, here are two links that might help you:
http://www.nifty-stuff.com/forum/viewtopic.php?id=1275
http://www.nifty-stuff.com/forum/viewtopic.php?id=1447
If you need more help, please answer these questions:
What type of paper, plain or photo?
A: Plain paper and High Resolution paper
Are you doing duplex printing?
A: NO
Are you sure your cartridges are in the correct positions?
A: YES
Does the nozzle check show any clogs?
A: I printed a nozzle check of the IP3000 with refill ink and IP6600D with Canon ink and they look almost the same.
What kind of refill ink are you using?
Some type of older Canon refill ink....I have so much I hate to throw it out.
What kind of cartridges are you using?
BCI-6 Carts made by Canon
I first printed the PDF file with plain paper selected and in draft mode just to save ink and it's definitly darker.ghwellsjr said:When you tell your printer that you are printing on PhotoPaper Pro or any other photo paper, it will not use any black ink. The iP3000 does not have a dye black cartridge so the scans that I provided in the second link above do not apply. I don't know how the iP3000 mixes its three colors to produce different shades of grey and black but I think you can understand why it is not pure black. You should try the greyscale test on photo paper to see if it is any better.
However, if you tell your printer that you are printing on plain paper and select greyscale, it will use only the BCI-3eBK pigment black and that should look pretty good.
Knightcrawler , I had exactly the same problem until recently with the MP 150. using Photo Paper pro setting at highest quality. (and cheepie refill inks)I first printed the PDF file with plain paper selected and in draft mode just to save ink and it's definitly darker.
