When it comes to sticking down your prints, it can depend on many things, that’s why there are so many good success stories out there but beware because your tried and tested method may begin to fail once you get use to using it.
My current method is working with a 95% success rate, because that is due to some carelessness on my behalf, for instance if I clean my glass after every print no problems and if I don’t then the print has a good chance of coming loose later.
I use this stuff to remove the previous used adhesive, but window cleaner works just as well, I’m now using 3DlAC as my main adhesive and heat the bed to 40c and give it a 1 second spray at 30cm.
My other printer came with a blue adhesive cover made of some sort of foam rubber and I didn’t expect that surface to last very long, but it has surprisingly, again I use the same spray and heat method and I have not lost one single prints yet.
The most important thing I found was to calibrate the bed height at normal printing temperature and set the nozzle low (Almost touching) and all your sticking troubles are over, you can always lower the bed a cat’s whisker later if you want.
Tip: - I found it easier to remove the print when the bed is still hot and even give a quick spray of cleaner to help...
P.S. Please remember everyone’s method works until it fails...Then a reappraisal is needed..
