neilslade
- Nov 3, 2004
I just got a really bad batch of CYAN BCI-6 carts manufactured by G&G (through inkgrabber)
I've used Inkgrabber's stuff for years- absolutely no problem- till today.
I ordered 6 CYAN BCI-6 carts for my 4 Canon i960 printers-
I immediately noticed OVERSATURATION of CYAN--
Then I noticed the ink was runny, and bleeding on the nozzle side of the head.
I've reported this to Inkgrabber who hopefully will notify G&G.
You can use this stuff, but you have to reduce the CYAN amount by -8 in your Canon printer and check the nozzles on the head, and invariably wipe off if the printer sits for any length of time.
Recommended that you avoid this G&G color till the problem and batch is fixed.
I've also noted that G&G carts are EXTREMELY difficult to refill because the refill plug has this nasty little black plastic plug in it- 50% of the time when I attempt to punch out the refill hole, and plug up (using Computer Friends blue plugs) the seal is not complete and the cart leaks.
I DO NOT RECOMMEND TRYING TO REFILL G&G carts. Use anything but. Canon carts refill easily, as do the old Rainbow Brand Carts.
