- Thread starter
 - #41
 - Nov 3, 2004
 - Bay Area CA
 - CR-10, i560 ,MFC-7440N
Thanks for all the great comments guys!
Just to clarify again: The end of the needle is pushed all the way into the non-sponge / reservoir section of the cartridge. I've tested this 100 times with the end of the needle right up against the prism, back 1/32 of an inch, and back 1/16 and 1/8. So, again, even though the video is misleading (too much ink blocking view, etc.) the end of the needle is not in the sponge side.
I've also tried many forms of "reverse pressure" with syringes pulling air from the reservoir and also another time removing ink from the sponge side. Additionally, I've tried tapping the cart to try to shift the sponge. Unfortunately neither process has made a difference.
What do you think about the size of the entry point hole in the plastic where the needle is inserted? Should this be a very tight fit to slow down air exiting, or should it be large to allow air to exit?
This raises the question: Where is the ideal place for air to exit out of the cart during the German refill method?
It seems that the major consensus is the cart being overfilled. I'll first test purging the tank (using a mix including Propylene Glycol ). If that works, I shouldn't see any ink wick back up the needle and into the sponge side during refill.
If that doesn't make a difference I may experiment with a slightly bent needle, larger entry hole, blunt needle, etc.
Any other ideas or comments? Please keep them coming!
