Well the the German method leaves a syringe hanging around afterwards with ink on the needle as well. It would make sense to always lay out an old tee shirt or towel before doing anything... mistakes happen. If you didn't try to refill to the max, then the tunnel would not have ink and the plug contamination is minimal and only at the tip, so the plug comes out pretty clean. The other trick is to tilt the cartridge a bit, since doing so will allow a greater fill without reaching the hole. as compared to keeping it level.  Sponge side is higher,  this also reduces the time the chance of overfill as well. Now if you filled up into the tunnel then that follows the greed theory and you got ink into the tunnel. You pay the price the next round of fill and thereafter. The other point is that the plugs I use cinches and seals at the bottom end of the tunnel and not the top. If you use the ones that seal at the top, then logically ink would seep into the tunnel and stop where the seal is which is at the upper part of the tunnel and you've got ink all over the plug to the point of seal.
About losing the plugs... well there's nothing you can do except maybe be methodical about what is carried out and where things are placed.
It's like my other half and myself as comparative cooks in the kitchen,when she's done, the place is a mess , when I am done it is not and cleanup is quick.
With the newer printers, this aspect might be moot because there might be limited choices in the method chosen.
