I had a problem with the CAP480 chart,
With the ES-2000 (aka i1Publish Pro 2), the chart is too big to scan...
It seems that the spectro needs to start on a white part of the paper, but when using the ruler from the ES-2000 it is not possible to start on a white section of the paper while also being able to get to the last patch
  • I was able to get it to work by resizing longer edge of the image to 90% of the original value, but is there a better way of doing this?
  • Profile and log attached, I loaded the profile into GamutVision but I do not know what to look for to figure out if it was done correctly
  • The plan is to wait a week before re-making the profile, what is a good way to store the print in the meantime? I just put it under a stack of other prints...
Edit: profile has to be renamed, I had to rename to txt to get it uploaded
Try this 924 patch target optimized for the i1Pro2 (ES-2000).
  • ArgyllCMS_924-patch_target_for_i1Pro2.zip
Loomray
Epson ET8550
I picked up a used(like new) i1PRO2 ,it will replace my old i1pro rev.D(EFI ES100 UV-CUT)
I´ve made some icc-profiles with ArgyllCMS.When i compere the same paper profile made with the i1PRO2 vs i1pro1(UV CUT)-
The whitepoint is shiftet towards blue .Is this the effect of Fluorescent Whitener Additive, or Optical Brightening Agents in the paper(SIHIL 280g) ,and the UV CUT Spectro make it neutral.
I made also a ICC-profile of an ILFORD Studio Pearl 260gsm paper with i1Profiler in dual-scan mode M1 D50,
and this has the same(litle more) blue shift.
You can see it in the 3d graph .The solid one is made with the i1Pro2 ,and the wireframe ist old UV-Cut i1pro.
Is this normal ? Do you have the same whitpoint peak offset the L axis?
You can see it in the 3d graph .The solid one is made with the i1Pro2 ,and the wireframe ist old UV-Cut i1pro.View attachment 16338
Yes I did have that off set too: towards blue. To really correct his you will need the OBC (Optical Brightness Compensation) profiling setting in iProfiler (you will need that special test chart with grey/black patches), but I am not sure because I do not have that special test target.
You can find the actcual whitepoint value in your Chromix software via the profile inspector - Tag Table - wtpt which displays the whitepoint value in various colorspaces incl. Lab.
The optical brightener is an add-on to the paper coating, and you need to include some points into your considerations
- do the typical viewing conditions for your prints contain any particular amount of UV in the ambient spectrum ?
This could be outside viewing light - with no glass in between - or older office lighting installations with neon tubes w/o sufficient UV filtering or room halogen light w/o UV filtering or ????
- But if you profile for outside daylight - with UV contents - you would need to change the standard viewing light spec from D50 to D65 as well.
- What it comes to is the problem that you try to profile your paper for different viewing light conditions at the same time - UV present or not - this ends up in a compromise .
- And be aware that the optical brighteners do the same as the regular inks - they fade - slowly - and are not effective anymore after some longer time. There is only one way to get out of that dilemma - using papers w/o optical brighteners. I'm only aware of one 'standard' paper - not special FineArt etc type papers - the HP Premium Plus Photo Paper does not contain any significant OBC amount.
You cannot do this - printing a test image with a M2 profile and one with an M1 profile, and then holding prints side by side for comparison - you are missing the UV light contents in the viewing light for the M1 print.
UtenteMac
Epson SC-P900
Hello everyone. I'm preparing for the next season of printer profiling (more or less every year during autumn, after the macOS upgrade).
I was revising my targen commands to improve accuracy on saturated colors and linearity of grey patches.
I often find "-g128" or "-g64" to distribute values along the 0..255 R=G=B axis.
Given that I work with 16 bit images (65,536 levels from white to black), isn't it just enough to specify "-g101" and let targen set gray patches at 1% intervals?
For QTR I've seen 51 steps wedges which seems to be already enough for most uses.
Thank you in advance.
That is perfecly OK. I suggest something like -g32 or -g64. Printers with K3 ink set will do fine with less grey patches.
HungTR
Canon Pro 1000
i am using the 480 patch from @pharmacist and the xrite i1studio to make profile but when i go and scan chart A this message "Raw Bands 24 - 33" and there is a color graph popup and then nothing happen after. I already redo it and everytime it just happen to have that message. What do i do wrong (first time with ArgyllCMS so a bit lost)
The scanning must be done very slowly and steady: start/place the scanning eye on a white area before the row (to be scanned) and press on the button. ArgyllCMS will give a peep sound, after this sound keep holding the button pressed (do not release) and move in about 4-5 seconds in a steady pace from white to white area and release when the scanning eye is again on area of white paper: ArgyllCMS will give a peep again and if succesfully the command will tell you to scan the next row, if not tap the space bare to rescan the row again. I presume you have installed the dedicated ArgyllCMS Colormunki/iStudio driver: you can not use the Windows driver that is installed by default. You will need to disable driver signing in Windows before the driver can be installed (check device drivers in configuration panel to see if the ArgyllCMS driver is active or the standard X-Rite i1Studio driver).
HungTR
Canon Pro 1000
i have done scanning but when i scan some roll it said "There is at least one patch with an very unexpected response! (DeltaE 81.310576)" and like 5 6 roll like that . When i see that i do i rescan of the roll but everytime it said the same with slightly different number on the DeltaE. and the profile i make when print it out there are some clipping in the blue area
I presume you did execute a nozzle check before printing your target ? If the nozzle check is ok I will try to upload another target for you this evening and try that one.
