- Thread starter
- #161
- Jan 4, 2012
- UK
- Canon Pro9000 II
Perhaps Graeme reads Printer Knowledge!
The read errors are clearly displayed if you make a mistake with any of the various patch sizes and you have to be more precise when reading the high density. The patch sizes vary between 10mm square with 480 and 7mm square with the most dense 957, so far, after cropping and resizing. I use a thin but opaque, matt black strip mask, with a slot 6.5mm wide for all patch reading, so with care (adjusting speed as appropriate) the ColorMunki appears (from the results) to know no difference and the resulting profiles appear repeatable (post #155 for example).
