- Thread starter
- #111
- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
Can you generate the ti3 file using a scrambeld patch set from the original ti2 file ?
I don’t have spectro for now. Still waiting but I can make all test patch for randomise and normal order for saving timeCan you generate the ti3 file using a scrambeld patch set from the original ti2 file ?
Can u send settings from windows app for cr30? I know it need to be in correct way and correct value on the table.Can you generate the ti3 file using a scrambeld patch set from the original ti2 file ?
Every nm manual or u can type range. agry use all of them? On test mode i only have SCI. On phone app i have M0 but not on QC2. I cant change UV settings containUV alsoHello,
I use
test mode (M0)
light source angle (D50/2 degrees)
L
A
B
400 nm
.....up to
700 nm
Be sure to check the scanning mode into D50 and 2 degrees, this is how the i1Pro does its work.
all other information I have removed
Im using photoshop to print and the target was printed using ACPU. Printer works just like normal one its EPSON L310. Weard about white because shoud be 85.27 i check it now again. White calibration cap also show 88.67. All files in zip ti1 ti2 tiff ti3Are you printing with a RIP or a standard printer driver: note the target is for RGB printer drivers and RIP programs need CMYK targets. The white value be about the Lab value above 90. x x. The 36.2 is very dark for white. Do you have a normal printer not for textile: try to make a standard RGB target for the normal printer.
Something is messed up. I don't know what your .colors file is. I generated an A5 10mm patch target from your 228 ti1 file with thisIm using photoshop to print and the target was printed using ACPU. Printer works just like normal one its EPSON L310. Weard about white because shoud be 85.27 i check it now again. White calibration cap also show 88.67. All files in zip ti1 ti2 tiff ti3
111(84.65 X X) and 68(83.97 X X) are white
