- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
I had a problem with the CAP480 chart,
With the ES-2000 (aka i1Publish Pro 2), the chart is too big to scan...
It seems that the spectro needs to start on a white part of the paper, but when using the ruler from the ES-2000 it is not possible to start on a white section of the paper while also being able to get to the last patch
Edit: profile has to be renamed, I had to rename to txt to get it uploaded
- I was able to get it to work by resizing longer edge of the image to 90% of the original value, but is there a better way of doing this?
- Profile and log attached, I loaded the profile into GamutVision but I do not know what to look for to figure out if it was done correctly
- The plan is to wait a week before re-making the profile, what is a good way to store the print in the meantime? I just put it under a stack of other prints...
Try this 924 patch target optimized for the i1Pro2 (ES-2000).
