x64
- Feb 21, 2025
- Epson Stylus R2400 2100 & more
That's a odd conclusion, and inherently false. Although grease is almost never a requirement for any mechanical system to operate, it is applied to prolong the lifespan of the parts against wear and erosion during use.I've never seen grease on plastic gears. If they were greased, they would be a mess of grease and dirt, but I've never seen one that isn't clean, even on an old machine. I sure wouldn't grease them.
When applying a excessive amount or the wrong type of grease, it can become a mess.
With the amount of plastic toys I took apart as a kid, I can assure you that whenever there's gears involved there will be lubrication.
