Magenta Banding Pro 10s
Paul Edmunds
Canon Pixma Pro 100s
Okay... based on what I can determine from the photos I think there's a dual issue at work here.
  1. The Magenta cartridge in use probably has a build up of pigment sludge on the internal filter mesh that sits above the outlet sponge and this is restricting ink flow.
  2. Given that the use of OEM carts (presumably with OEM ink in) the fact that the issue doesn't disappear indicates that the sludge has also permeated into the printhead and is probably blocking the magenta channel as well.
So... a few remedial courses of action..
First off, it's worth keeping in mind that the printhead may already have some damage to the nozzles so this may be a bit late but still worth trying to recover it. That aside..
  1. Clean the printhead manually using cleaning solution and a whole heap of borrowed patience as per:
  2. Consider purchasing a fresh batch of the magenta ink or at least start using your most recent 2024 batch (if my records of orders is correct)..
  3. Flush your Magenta cart using cleaning solution then rinse throughly with deionised or distilled water, removing all the solution between each clean/rinse. Then re-prime as per:
Assuming you manage to clean out the printhead and remove the sludge from the filter you should find that ink flow resolves itself but again just remember the printhead may be a bit past help.
Thank you all for your help. A genuine Magenta cart and a few deep cleans has solved the problem, it's now printing beautifully. I'll call Octoinkjet to see what they say.
Thank you again.
Paul
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
As long as I refill with 3th party inks I always inspected nozzle checks with a magnifying glass to detect the first signs of clogging.
Red pigments have been the most suspicious. As discussed magenta was the only color where Octoinkjet had some clogging issues. Except for Precisioncolors I never found any other reliable Canon pigment ink provider.
As said, with prudent management you can reduce printing costs without ruining the printer.
Artur5
Kmt. 0.
My Pro10s sees very little use nowadays. ( I reduce printing costs by not running the printer... :rolleyes: ).
In all likelihood, the compulsory cleaning cycles use more ink than the actual ink layered on paper. Not a wise policy, I know, because the less you print, more chances of eventual problems. Nevertheless, as seven inks are OEM from Canon large capacity tanks, I've had no clogging issues for a long time ( knocking on wood ..).
