What 3D printing project are you working on today?
Redbrickman
Brother MFC-L8690-CDW
PETG would certainly be more robust as it has a little bit of flex in it, however I'm sure it will do the job and if it all goes pear shaped then print another with MK2 enhancements. Even as I write this I can almost hear @The Hat thinking about Johnny 6 :)
Nifty
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
Ah Ha, the big question is.. Did you use a metal bolt or a plastic one ?
LOL, It has an embedded nut on one side for a nice fat bolt :)
Nice design !
If I had to print this part, I'd choose a filament slightly flexible and with good outdoors endurance like PETG or ASA, but given your predilection for PLA, it seems a moot point asking which filament you'll use, isn't ? ;)
Actually, I'm testing the fit in PLA, but I'm going to probably end up printing it in 95A TPU for strength, heat-resistance, and so it will "grab" onto the smooth metal a bit better.
Artur5
Kmt. 0.
I wouldn't use TPU for heat resistance. It's on a par or worse than PLA.
Redbrickman
What about printing a strip of TPU maybe 5-6 layers high and glue to the part where it clamps on the bars?
Nifty
Administrator
Bay Area CA
Fair point on TPU, though from what I’ve seen, its heat resistance is still a bit better than PLA... usually around 60–80°C vs PLA’s 55–60°C. But yeah, it’ll definitely still soften if it’s under pressure in a full sun. I might end up switching to PETG and doing that TPU strip idea.
I think for now I'll test TPU and see how it goes. Also, I even think PLA would work because there is a bit of thermal mass to the part, and my bike is rarely in super-hot situations for long.
Go with your first idea, PLA will be fine, trust me I’ve been using it for years.. :lol:
The mark VI is on the drawing board, and so is a manual old water pump..
