Some lithium rechargeable AAA batteries were delivered today. I want them for things that don't work well on the lower voltage of NiMH cells. I got the type that you just stick 5v across to charge. I have bench power supplies and could get 5v from many USB sources. I needed a holder that would take 4 batteries to charge in parallel.
I designed and printed this
Battery contacts were the problem which I solved with some adhesive copper tape and some 8mm springs I already had. You can see the copper tape for the battery +ve contacts. There is another strip of tape below the springs.
I placed lugs on the side for the tape to wrap around and was going to connect to them with crocodile clips, but, I decided they could chew up the tape too easily so I soldered wires to the tapes and anchored them with some hot melt glue.
I split the thing in two with a dovetail joint so it could be printed without supports and allow the tape to be embedded adhesive side down. Surprisingly the dovetail joint was a nice fit first try and I made it permanent with a bit of superglue.
