What 3D printing project are you working on today?
Brother MFC-L8690-CDW
PETG would certainly be more robust as it has a little bit of flex in it, however I'm sure it will do the job and if it all goes pear shaped then print another with MK2 enhancements. Even as I write this I can almost hear @The Hat thinking about Johnny 6 :)
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
Ah Ha, the big question is.. Did you use a metal bolt or a plastic one ?
LOL, It has an embedded nut on one side for a nice fat bolt :)
Nice design !
If I had to print this part, I'd choose a filament slightly flexible and with good outdoors endurance like PETG or ASA, but given your predilection for PLA, it seems a moot point asking which filament you'll use, isn't ? ;)
Actually, I'm testing the fit in PLA, but I'm going to probably end up printing it in 95A TPU for strength, heat-resistance, and so it will "grab" onto the smooth metal a bit better.
I wouldn't use TPU for heat resistance. It's on a par or worse than PLA.
What about printing a strip of TPU maybe 5-6 layers high and glue to the part where it clamps on the bars?
Administrator
Bay Area CA
Fair point on TPU, though from what I’ve seen, its heat resistance is still a bit better than PLA... usually around 60–80°C vs PLA’s 55–60°C. But yeah, it’ll definitely still soften if it’s under pressure in a full sun. I might end up switching to PETG and doing that TPU strip idea.
I think for now I'll test TPU and see how it goes. Also, I even think PLA would work because there is a bit of thermal mass to the part, and my bike is rarely in super-hot situations for long.
Go with your first idea, PLA will be fine, trust me I’ve been using it for years.. :lol:
The mark VI is on the drawing board, and so is a manual old water pump..
Epatcola
various
Some lithium rechargeable AAA batteries were delivered today. I want them for things that don't work well on the lower voltage of NiMH cells. I got the type that you just stick 5v across to charge. I have bench power supplies and could get 5v from many USB sources. I needed a holder that would take 4 batteries to charge in parallel.
I designed and printed this
Battery contacts were the problem which I solved with some adhesive copper tape and some 8mm springs I already had. You can see the copper tape for the battery +ve contacts. There is another strip of tape below the springs.
I placed lugs on the side for the tape to wrap around and was going to connect to them with crocodile clips, but, I decided they could chew up the tape too easily so I soldered wires to the tapes and anchored them with some hot melt glue.
I split the thing in two with a dovetail joint so it could be printed without supports and allow the tape to be embedded adhesive side down. Surprisingly the dovetail joint was a nice fit first try and I made it permanent with a bit of superglue.
Administrator
Bay Area CA
That's fantastic!
I've printed a handful of different battery holders and connectors. Some using stripped wire wrapped around a terminal as the connecting point and just pressure holding the battery in place, and other ones with 3D printed springs pushing the contacts into the batteries.
Next time I do this, I'll probably dig around for some of the springs and contacts that I've pulled out of various electronics. Period. Definitely a better way to go than what I did before.
Your use of springs you had on hand and the copper plate is brilliant.
Epatcola
various
I already had this box of springs from Aliexpress. I made the holes they fit in snug so they don't fall out. I had a strange problem with the springs not making electrical contact with the tape. I bent the wire at that end of the spring towards the centre and outwards to make a sort of prong after which contact was fine.
