buying advise 3D printer
Hello everybody,
Having alot of experience with 2D printers the last decades, I want to enter the world of 3D printers. Any tips about a good 3D printer that I can buy, using good aftermarket filament, heated versus non-heated beds, ease of cleaning of the printer, sound production, fitting on narrow IKEA Kallax (d: 37 cm), closed system. Not sure this is a good printer:
Bambu Lab P1S 3D Printer​
Many thanks for the input.
Artur5
Kmt. 0.
WARNING : You're about to open a deadly can of worms. Think twice (or thrice ) before entering into the 3Dworld, a land of no return.
I did the fatal mistake four years ago and, believe me, there's no cure once you're bitten by this bug... :p
Artur5
Kmt. 0.
My first printer was a Prusa, still on good working order, but I won’t recommend any of their current models,
The reasons aren’t easy to explain in a few words but if I were starting now on 3D printing, I’d pass on Prusa,
Bambulab is the big name these days but I don’t like their business model, Proprietary software, dubious customer support, compulsory icloud account, etc..
So, my recommendations are what I wouldn’t buy instead of what I’d buy.
Of course, that’s just me. Thousands, even millions of users sure do love like their Bambulabs, Prusas or Crealitys.
If you’re totally new on 3D, don’t commit yourself too soon to a certain brand or model until you know more about 3D printers.
Take your time on Internet browsing forums until you get a better idea of how 3D printers work, how they’re build, what is a slicer, hotend, extruder, heatbreak, etc.
P.S.
My former message wasn’t totally a joke, not when I think of how much I’ve spent on this thing the last years..:rolleyes:
Of all the printers I have bought in the last 8 years, Creality have been for me the best, they make small as well as large printers so look at what they got and pick one.. Or go to some other brand, in a nut shell a 3D printer is a 3D printer and it will get you hooked whichever you choose very quickly..
You have to be born before you can learn to crawl, so burn your fingers on something small !
As far as advice is concerned, for me I like to stay away for these printer forums because everyone has their own agenda, loves / hates are expected, but some comments are downright nasty and not worth considering..
The best 3D forum I found was right here on Nifty, because nobody has an axe to grind and all advice is given in good spirit, my level of competence is all down to Nifty members advice and they have never steered me wrong, originally Rob got me started..:hugs
x64
Epson Stylus R2400 2100 & more
I've had some experience with both Bambu Lab and Creality, personally would go with Creality for a cheap learning experience for understanding the printer, troubleshooting upgrading etc. You will be learning about Flow Rate, Pressure advance, Z offset, calibrating extruders and more. And there's plenty of substantial hardware upgrades to install.
Bambu Lab printers on the other hand are great if you want to just buy a machine and print reliably, but don't care much about tweaking parameters or pushing the limit. Most things are preset properly especially if you use their filaments. You can obviously tweak things yourself but that's not really what the product is intended for.
But beyond the big names there is plenty of DIY projects out there that make a better printer or push the limits in different ways. If you can follow an advanced guide, have some assembly experience and free time those are great projects. When starting fresh like you I would look there, as you'll be building everything yourself and learn and know everything about the machine. Watch some video's on Youtube showing the current up to date lineup of available projects.
Redbrickman
Brother MFC-L8690-CDW
I'd stay away from Bambu printers if I was in the market for a new one. They are continually locking down their firmware to keep people in their own ecosystem, e.g. they are reportedly now making it impossible even to use 3rd party slicer software. There is also a lot of concern regarding their security.
Personally for a starter printer I'd try a QIDI plus 4. Reasonable priced and one of the few that has an enclosed and heated chamber so you can print some of the more exotic filaments. They are also introducing a multicolour add on box what will allow you to have 4 separate coloured filaments, much like the Bambu AMS system.
If you really want to tinker then you could build one of the Voron range of printers. There are kits available that pretty much has everything you need. If you go down that route I'd recommend buying an LDO kit as theirs is high quality and had good build instructions. I built my Voron from scratch befoe anyone made a kit. It was a long process but enjoyable, the wiring was the hard part but if I had to do it again I'd get a kit.
If you just want to dip your toe into the murky waters of 3D printing then there are cheaper alternatives with many "bedslinger" models available such as the Ender 3 V3 which is a solid little printer.
Whichever you choose make sure there is a good community forum for the printer. There are some great printer communities on Discord which would be worth joining if you are researching.
Voron - https://discord.gg/voron
Qidi - https://discord.gg/F4C6MjQm
Creality and others have Discord communities too but I don't follow them.
As far as a support or table is concnerned you really want one that won't wobble around as it can affect the print quality.
I think you will enjoy it as you have clearly spent lots of time tinkering with printers and inks so there is plenty of scope in the 3D world to keep you happy ;)
The battle to get a good first layer and good adhesion to the build plate is the first level of apprenticeship that is the hardest part of the learning curve :)
Artur5
Kmt. 0.
The long and winding road to 3Dland ..
Voron for me, but I guess that one must be a bit nuts to choose this road, isn't so Redbrickman ? .:p
Nevertheless, looking back after more than two years, I'm now totally sure that my choice was right.
When I've had trouble with a Voron, it was because of my lack of skills or experience in 99% of the times. That's not the case with most of the commercial brands. Endless iterations of buggy firmwares, poor quality components, dumb designs ,sloppy assembled parts and what not. Prusa, I'm looking at you, but I guess that this is to be expected with the vast majority of 3D printers whose manufacturers have profit as the main goal. This is where Voron is different. Their community team designs the machines for the best performances, regardless of the cost, because they don't sell the printers.
Tony4597
Cheshire, UK
Epson Surecolor SC P800
With one major caveat (see below) without a doubt (at least for me!) the P1S is a very good printer if you just want to actually print virtually straight out of the box, as the printer calibrates itself very well prior to printing. Print quality is excellent and a match for the more expensive X1C. The main difference being the Lidar and spaghetti detection of the X1C plus the much better camera and Display screen (moot point if you use either a PC or Bambu Handy on iPhone or Android)
Currently running both Bambu Lab software and Orca slicer.
Caveat: I am currently sticking with P1S Firmware v1.07 as the new so called security firmware update v1.08 may break (likely?) the link to Orca slicer.
TBH I have not investigated this properly but if the link is broken then the only way to use Orca would be sending Orca generated gcode to micro SD and loading manually into the printer. It would not be a killer for me but those running print farms of P1s well...
Additionally it is not clear to me if it is possible to roll back firmware to older versions and it would seem unlikely to be the case with a new purchase as it is assumed that the new firmware would be standard with no backward path
Sadly it seems that Bambu Labs CEO is following a similar path to Apple which AFAIK requires Apples approval for developer software when going through the App store
Previously running a Creality clone which did require a degree of fiddling with bed levelling, probe heights and gcode. I guess all the systems will have improved dramatically since mine in terms of performance, print quality and slicer choice
Orca slicer offers a slew of calibration options including Flow rate, pressure advance, retraction, tolerance tests for fine tuning filament.
Bambu filament is good as is many other less expensive brands such as Sunlu etc etc.
For a very similar spec the Elegoo Centauri Printer looks to be very good value at £300 vs P1S. But P1S prices have now dropped considerably and currently stand at £379!! Currently Elegoo do not have a multi colour AMS but this is due sometime this year
Question for me is would I buy into Bambu systems again if buying new. TBH I am not sure!
Epatcola
various
I also can no longer recommend Bambu Labs. When it comes to privacy and security they are simply incompetent and dishonest. I don't trust the company any more.
They have locked out 3rd party access to/control of their printers siting complete BS security and safety reasons. They offer a crappy and completely pointless 'shim' application Bambu connect and a printer developer mode workaround introduced after the shitstorm created by users on the introduction of this authentication security crap. I don't really trust developer mode or its' future availability so my X1C will be running on obsolete firmware for the rest of its life.
Annoyingly I have so far earnt enough points on their Makerworld site to get a free P1S combo. I was expecting to put them towards a next generation printer but I will probably end up spending them on a few spares and a crap load of expensive Bambu filament I don't need.
Tony4597
Cheshire, UK
This thread got me thinking about printer connections again and updating firmware etc. FWIW some thoughts but as yet, for me no conclusions>
  • Firmware updates.
    Well my P1S and AMS is working without issue so far no need to update and add features that I have no use for. If it aint broke why try to 'fix it'?
  • If a good reason/feature to update firmware is flagged then perhaps LAN mode will be the answer to using slicers other than Bambu own?
  • Trying to figure out the pros and cons of LAN only
    • Pros
      • Keep everything local with no reliance on cloud based services which can fail or be halted at the wrong moment!!
      • No more sending and receiving data from Bambu servers so security is the users responsibility
      • Keeps printers data private.​
    • Cons​
      • Cannot start prints outside of the LAN​
      • Cannot use Bambu Handy app​
      • No access to Print History​
Actually the listed cons do not really matter to me so something that may be an option for the future?
Found this on Github
https://github.com/SoftFever/OrcaSlicer/issues/8099
I have a lot of time for this guys views on 3d printing
