PalaDolphin
- Jul 25, 2016
- Saint Paul, MN
- Canon Pro-100, HP 7760, RX500
The strategy that I'm most comfortable with, as explained by @jtoolman, is to swap out all ink cartridges once just one becomes low. This reduces the number of cleaning cycles run by the printer whenever even just one ink cartridge is replaced.
For purposes of this discussion, "first carts" refers to my original Canon OEM ink cartridges that came with my new Pro-100 printer and "second carts" refers to my flushed cartridges refilled with Precision Colors' (PrC) ink.
Currently, BK and GY carts are 30% used while PC and C are only 10% used; yellow is 25%. In the race to the bottom, I'm sure BK will become low first. (I have another printer I could use for business printing, but it's old, has clogged color ink jets, only black works consistently, must be connected via USB, no WiFi, and space near my desktop is at a premium. So, the little business printing on plain paper will be done on my Pro-100 for now.) Eventually, I will be using only PrC ink, but for the first carts, I'm not sure what to do with the Canon ink.
I understand and accept throwing out and completely flushing the yellow cart from the first carts; there's no mixing yellow ink with anything. It's all the other inks I don't know what to do with.
So, let me set the scenario. One ink reports low. I pull the first carts and replace them with the second carts. I flush and refill the yellow cart with PrC ink; that's a given. Now I've got seven other ink carts from the first carts with various levels of Canon ink. Do I,
Since this is my first time, I'm only going to have to deal with this situation once. I'm just not fond of throwing out expensive Canon ink, if you know what I mean. I'm a man of limited means.
A. Drill out and remove the ball on the first carts while they still have Canon ink in them and top them off with PrC ink mixing the two?
B. Are the ICC color profiles so close between the two inks that I can use one or the other while using mixed inks.
or...
C. Throw out all the original Canon ink when the first cart becomes low and start fresh with PrC ink?
or...
D. A hybrid where, just initially, only replace one cart from the first carts one at a time until I'm no longer dealing with Canon ink and how do I deal with ICC color profiles when I've got a mix of Canon and PrC carts in the printer at the same time?
or...
or...
