- Jan 18, 2010
- Residing in Wicklow Ireland
@glprint, The refilling procedure for these carts is not plain sailing at all. so, I reckon you have some air still left inside your carts, you could try covering all of the air inlets on the cart as in the instructions, and then stand the cart with the outlet facing up and tap the cart a couple of times on your desk, this should dislodge any trapped air.
Then insert a syringe with the proper tip attached and withdraw the plunger just enough to draw some ink out of the outlet hole, do this with any of the carts that are causing feeding issues.
Please report back afterwards...
