- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I think this is about one of the printers mentioned in your profile, maybe the Canon iX6840? This is a 5 cartridge printer using the PG-450 pigment ink cartridge and the CLI-451 CMYK dye inks cartridges. This explains the use of refillable cartridges, as one or more sets of OEM XL cartridges plus a resetter would be more expensive.
Your remark about a perfect nozzle check makes me think about Ink starvation, as a nozzle check uses much less ink than a "more normal" document. Could you upload a scan or photo of a print showing the problem? You can crop the image to remove personal info. Else a Windows printer test page might also show the problem.
Did the cartridges behave OK before the temperatures dropped below freezing?
