- Apr 19, 2007
- USA
- Canon MB5120, Pencil
What are these supporting software you think will help you "dial up the performance". Unless things are significantly different, no Canon software has improved my images beyond a couple basics effects. There are third party apps for enhancing images.As I said a few posts ago I am going to try to dial up the performance of the Canon via the supporting software.
Images printed on Canon printers may look quite different than on Epson printers and vice versa. One paper works well with Canon inks and not with Epson inks. Profiling your printer, paper, inks, and monitor can help with continuity of performance.If in fact the Canon can produce the same sort of color performance that the Epson does
You are correct. No free lunch.I would expect that the higher quality settings also mean a reduction in speed
Remove from your thoughts about using aftermarket or "remanufactured" carts. The former may lead to catastrophic ink leaks and/or print head failures, while the latter is not something I am aware of being offered. Instead, do you mean "refurbished" such as buying a used empty OEM Canon ink cartridge from Precision Colors: http://www.precisioncolors.com/c6c2cart.html?it will be easier for a guy like me to use remanufactured tanks and aftermarket ink
(The above link is for refilling products for the MG8220)
