RogerB
- Sep 27, 2010
- S.E. England
- Epson Pro3880
I think it is worth saying to anyone using Argyll (or any other profiling application!) that if you have to keep re-reading, it means that the overall quality of your readings is poor. Re-reading does not make a significant improvement in the average errors of the readings. If you have to keep re-reading, then try changing your reading technique until you can eliminate the re-reads. As for enhancing the profile, the answer, unfortunately, is no. If the measurements are bad the profile will be bad.Though I got successful after re-read each row many times, both profiles are problematic as you can see in the picture above. Can we enhance the .icm profile beside re-read?
