ThrillaMozilla
- Jan 18, 2011
If I understand you correctly, you put in a new OEM magenta, everything was fine, then you started to tinker again. Just put in the new cartridge, do a head cleaning, and then LEAVE it in. Leave the printer turned. on. If everything is still fine and remains fine, then your problem is solved. And you know there is a problem with your other cartridge or with your refilling technique.
