- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
There are two main causes of ink flow problems. Either there is a problem with the cartridge or there is a clog in the fine ink passages in the upper part of the print head.
I admit it is a bit expensive, but the best test tool to determine if the problem is a cartridge problem is a new Canon OEM cartridge. If the new cartridge solves the problem you know that the refilled cartridge was the cause, and a flushing of the cartridge might solve the problem. If the new OEM cartridge makes no difference you know that there is a print head problem.
Here is a post with a couple of tests to determine the condition of the refilled cartridge. And here is a thread about a problem that was most likely caused by an airlock in a refilled cartridge.
The purge unit might also be a cause of problems, see this thread. And here is a purge unit test by turbguy.
