- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
I did actually look into this as I had thought that a flexible epoxy (One I've used to great effect in other plastics projects) would be more appropriate but every unit I built failed in a matter of minutes.I wonder if there would be pros and cons to some epoxy that tends to be stronger and more brittle vs. some that tend to be less strong, but slightly more pliable / flexible?
Regular araldite and other brittle epoxies just snapped apart if I wasn't careful... and truth be told I didn't think the hot glues would be much better until I tried using it in the name of empirical research. Given that Poly Prop' is not the best plastic to be bonding to other plastics anyway I was more than a mite surprised that the bond was so strong.
I don't doubt that individuals with a lot of time to kill could create a very solid DIY clip with all manner of over-engineering though, so doubtless someone will make it a project..
