- Thread starter
- #261
jctay
- Sep 18, 2026
- Canon Selphy CP1500
Your question comes at a good moment, because ChromIQ 4.3.41 is out with something for exactly this:
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.41
New beta option, for the i1Pro 3 only: one scan saves M0, M1 and M2
- Switch it on in Preferences, on the Beta tab. It is off by default, and with it off nothing changes.
- The i1Pro 3 lights the paper with and without UV in the same scan. ArgyllCMS computes M0, M1 and M2 from that one scan, and until now ChromIQ kept only one of them. With the option on, your measurement stays exactly as it is, and the other two conditions are saved beside it, in a folder "conditions" inside the run.
- In Build Profile there is a new choice, "Build from", in Guided and in Manual. It decides from which of the three the profile is built. The profile's description then says "-M1" or "-M2", and Check & Refine judges the profile in the same condition.
Measurement Conditions M0/M1/M2
Can you confirm whether a measurement set can be configured to use only one measurement condition (M0, M1 or M2), or whether multiple conditions can coexist within the same set?
