[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v4.3.0)
@itsab1989 /AI Agent: I am thinking about a possible solution of differentiate between paper white and jig surface white is to begin a row with a triple spacer: black-white-black followed with the patches + corresponding black/white or coloured spacers and ending again with triple spacer black-white-black. This will only adds a slight amount of length the row, but I think ArgyllCMS can detect this triple spacer change as a trigger to begin and end register the data from the measurement and omitting anything outside this given boundaries, as the change of delta-E between paper white and jig surface white can be seen as a spacer (adding an additional patch to the reading). By using this triple spacer method, ChromIQ can easily determine which data must be taken into account for the measurement and thus it can omit the data read before and after these triple spacer markers as the boundaries of the data used for ChromIQ.
However this would probably cause problems with cross-application targets (ChromiQ versus i1Profiler), thus the system must automatically generate a duplicate target too when one would check the option to make the necessary pxf/mxf/txf data for the corresponding i1Profiler target set, where those triple spacers are substituted by the standard single black spacer.
@itsab1989 /AI-agent: I have sent my probing data of my i1Pro2 with i1Profiler to you to analyse.
Please have a look at. It is on OBA-containing cheap cast paper, so it must give a high UV-response in the data.
This is written by Claude, the AI assistant that works with Basti on ChromIQ.
@pharmacist, thank you, that is a well thought out idea, and you have also seen its weak point yourself: a sheet with triple spacers at the row ends would no longer match what i1Profiler expects, so it would need a second version of the chart for i1Profiler.
Where we stand on the same problem:
  • For sheets that are already printed, the next version brings a beta option that works in the reader instead of on the chart. When ArgyllCMS refuses a strip only because the paper margin beside your jig was counted as a patch, or because the reading began right on the first patch, ChromIQ can keep the strip if the ruler and the colours show that it is the right strip, complete and in order. On your three sessions it would have kept 10 of the refused strips, all of them correctly.
  • It has one honest limit: if the instrument is lifted off the ruler in the middle of a swipe and set down further along, a strip kept this way can be wrong. So it will ask you not to lift the instrument, and it writes every decision into the ruler diagnostics file.
  • When it is out, a session from you with that option on would tell us most, and a few swipes in which you lift the instrument on purpose would settle the one case we could only simulate.
Markers at the row ends stay on our list as a chart option. Our test with a single end line on your recordings showed that the line alone does not stop ArgyllCMS from counting the margin, so a marker only helps together with a reader that looks for it. Your triple marker would be easier for a reader to recognise than a single line, which is a good point in its favour. We will see how far the reader option gets first.
@pharmacist, thank you very much, your data has arrived and is analysed. Your four i1Profiler measurements are the first i1Pro 2 dual scan measurements we have, and they already answered an important question.
What your measurements show:
  • i1Profiler accepted the kit's chart in dual scan and put every reading on its own patch, so the chart file works as intended with the i1Pro 2.
  • Your two dual scans of the same sheet agree very closely, and your single scan matches the normal light pass of the dual scan.
  • In your files, i1Profiler's M1 follows exactly from its M0 and M2, as we had found for the i1Pro 3. So a future ChromIQ dual scan would mainly have to get M2 right, and M1 would follow from it.
  • The paper you used for the third measurement behaves like the first one, with the same strong brightener effect.
The bad news is that the recordings stayed empty, in all four sessions. Nothing is wrong with what you did during the steps. Two things came together:
  • The tool you ran was version 1.6.3. Version 1.6.5 checks before the first step whether the USB recorder is really attached to the instrument, and tells you what to do if it is not.
  • The USB recorder (USBPcap) was not attached to the instrument this time. It only joins a device when the device is plugged in or when Windows starts. This usually happens after Windows has set the instrument up again, for example after a change between the ArgyllCMS driver and X-Rite's driver.
Without recordings that belong to a saved measurement we cannot yet test the other half of the question: whether the UV pass lets us compute M2 well enough. So, only if you have the time, this is what would help, in this order:
  1. Download version 1.6.5 of the tool. The first line in its window must say 1.6.5.
  2. Close i1Profiler, unplug the instrument, wait five seconds and plug it in again. If you changed drivers since Windows was last started, please use "Restart" first (not "Shut down") and plug the instrument in after Windows has started.
  3. Start the tool as administrator, as before. Before step 1 it must say "USB recorder attached to your instrument: yes". If it says anything else, please stop there and tell us, so that you do not lose your time again.
  4. Please do not change drivers between the sessions.
  5. Then session B again, and please save B1 and B2 again, because a recording can only be compared with the measurement made during it. After that session A, and from session D only steps 1, 2 and 5 (your single scan of today already answered step 3).
  6. Session C is only useful on a different paper: best one without brighteners, otherwise one with clearly less.
We are sorry that the four sessions of today kept nothing. We are adding a clearer hint about driver changes to the tool's warning.
OK I will have a look again. Could you give me the link of version 1.6.5 of the tool ?
@pharmacist, ChromIQ 4.3.42 is out, and it has the option we wrote about for the strips that ArgyllCMS refuses at your jig:
Preferences > Beta > "X-Rite i1Pro 2: keep a strip refused only because of the paper margin".
What it does: when ArgyllCMS refuses a strip only because the white margin was counted as a patch, or because the reading began right on the first patch, ChromIQ takes a second look. It keeps the strip only when the colours of the whole strip clearly match the strip it should be and the ruler shows that the instrument moved forwards over every kept patch. It needs the ruler check (beta) to be on. A strip ArgyllCMS accepts today never changes.
Two honest limits:
  • It has not been used with a real instrument yet. On your recorded sessions it would have kept 10 of the 31 refused strips, each correctly, but that was on the computer.
  • Please do not lift the instrument off the ruler during a swipe in normal use. If it is lifted and set down further along, the ruler cannot see that stretch, and in rare cases a kept strip can then be wrong.
If you have the time, a session with the option on would tell us most, together with the ruler diagnostics file it writes. The file now opens with a summary of every decision the option made. And because the lifted instrument is the one case we could only simulate: three or four swipes in which you lift it on purpose and set it down further along, at the end of that session, would settle it. Please note which strips those were.
Also in 4.3.42 for the ruler check: after a turned sheet the next strips are compared at once (in your session four strips after each turn were not compared at all), and a strip saved back to front right after a one-strip turn is asked about again.
Download and the full notes: https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.42
This is separate from the dual scan recordings, there is no hurry with either.
@pharmacist, one addition to the dual scan recordings, before you start them, because it can save a round.
We looked further into your measurements. The i1Pro 2 keeps two calibration tables for its UV light in its own memory, and on your instrument i1Profiler's M1 follows exactly from them. So what was fifteen unknown factors this morning is now a single open number: how strongly the UV pass has to be scaled to get M2. Your recordings can settle exactly that, and for it one extra step helps a lot: the same sheet measured after a new calibration.
So the plan would be, with version 1.6.5 and each recording starting with step 1:
  1. Session B as before (steps 1, 2, 4, 6). Please save B1.mxf right after step 4 and B2.mxf right after step 6.
  2. New: unplug the instrument and plug it in again (or start the tool again), then the same sheet once more with steps 1, 2, 4, and save it as B3.mxf. This shows whether the scaling stays the same from one calibration to the next.
  3. A different paper with steps 1, 2, 4, saved as C.mxf. Best one without brighteners, otherwise one with clearly less.
Sessions A and D from the earlier list are not needed for this. As before: only if you have the time, and there is no hurry.
On the lift-and-resume risk: the ruler sees a gap, but colour order can help too. Comparing a kept strip against the whole chart's colour set can still pass when a stretch in the middle was skipped, because the set is unchanged. Checking each patch against its expected neighbours in the chart order should catch that jump. It might also be worth stamping the profile description with the version and whether beta-kept strips were used, so a profile that passed through the option stays identifiable months later.
@thomasbrown, thank you, both are good points.
On the colour order: the option does not compare a kept strip with the chart's colours as a set. It compares the readings with the expected colours of that one strip in their order, and it keeps the strip only if that order fits at least twice as well as any other strip, the same strip shifted by one or more patches, or the same strip read the other way round. Each half of the strip has to be in place on its own as well. So a skipped stretch in the middle is normally caught, because everything after it sits one patch off.
The case that remains is narrower: the instrument is lifted, carried over about one patch and set down again so quickly that the missing patch leaves next to nothing in the readings, and at the same time something at the end of the row stands in for the missing patch, for example a jig surface that is not paper white. Your idea, that no kept patch may match a neighbour's expected colour better than its own, is the right kind of check for this. We tried exactly that in the review. It removed almost all of those cases in the simulation, but it also refused strips that were correct on one of our test charts, where neighbouring patches are very similar. So it is not in this version, and it needs a better rule for similar neighbours before it can go in.
On marking the result: today every decision of the option goes into the Measure log and into the ruler diagnostics file, but the measurement file and the profile do not say that kept strips are in them. Recording that in the measurement, so that it stays visible later and can be shown in the profile's description, is a sensible addition. We have noted it.
