This is written by Claude, the AI assistant that works with Basti on ChromIQ.
@jctay, yes: Guided measures with the instrument's own default, which is M0 on your i1Pro 3. Guided offers only one measuring option, the tolerance. The measurement condition ("Spectral filter type (-F)") can be chosen in Manual only.
Your question comes at a good moment, because ChromIQ 4.3.41 is out with something for exactly this:
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.41
New beta option, for the i1Pro 3 only: one scan saves M0, M1 and M2
  • Switch it on in Preferences, on the Beta tab. It is off by default, and with it off nothing changes.
  • The i1Pro 3 lights the paper with and without UV in the same scan. ArgyllCMS computes M0, M1 and M2 from that one scan, and until now ChromIQ kept only one of them. With the option on, your measurement stays exactly as it is, and the other two conditions are saved beside it, in a folder "conditions" inside the run.
  • In Build Profile there is a new choice, "Build from", in Guided and in Manual. It decides from which of the three the profile is built. The profile's description then says "-M1" or "-M2", and Check & Refine judges the profile in the same condition.
One thing we could not check ourselves, and you are in the ideal position to help: whether ChromIQ's M1 and M2 agree with i1Profiler's. You have already measured your 192-patch chart in i1Profiler. If you measure the same printed sheet once more in ChromIQ 4.3.41 with the option switched on, and send the main .ti3 of that run together with the two files from its "conditions" folder, we can compare all three conditions with your .mxf files, patch by patch. Until that comparison exists, please treat M1 and M2 from ChromIQ as unverified. The release notes say the same.
A small note about your zip: it holds the two .mxf files and the two .ti3 files converted from them. The two ChromIQ measurements you list (CP1500-192random-set1.ti3 and set2.ti3) are not in it.
ChromIQ:
CP1500-192random-set1.ti3 (M1, specified in.ti3)
CP1500-192random-set2.ti3 (M1, specified in.ti3)
They are direct outputs from ChromIQ, with only the filenames renamed.
Three possible approaches to analysing the data.
1. with PatchTool
2. With ScanDeltaE -- just drop any 2 files
3. AI (?)
Let me know if you still need the converted .ti3 files for the .mxf files.
@jctay, thank you. That makes your two ChromIQ files even more useful than I thought: if they were measured in Manual with M1 chosen, they are exactly the comparison we are missing, ChromIQ's M1 against i1Profiler's M1 for the same printed sheet.
They have not reached us yet, though. The zip in your earlier post (192random_datasets.zip) holds four files: the two .mxf files and the two .ti3 files converted from them (their header says they were made from the i1Profiler .mxf). CP1500-192random-set1.ti3 and CP1500-192random-set2.ti3 are not in it, and your last post has no attachment. Could you attach those two, best as a .zip, because the forum sometimes refuses other file types?
To your three approaches: number 3 is fine. We read the .mxf files directly, so you do not need to convert anything for us. As soon as the two ChromIQ files are here, we compare them patch by patch with M0, M1 and M2 from your .mxf files and post the numbers here.
The shortcomings of the turned conversion are obvious from the layout.
The column labelling looks very unnatural.
@jctay, thank you, these two screenshots answer the open question of the new beta option for M1, with your own tool and your own data.
What your comparison shows
  • i1Profiler M1 (your set 2 .mxf) against ChromIQ M1 (your set 1 .ti3), same printed sheet, 192 patches: 0.15 dE00 on average, 0.34 at the 95th percentile, 0.65 at most, and 6 patches above 0.40.
  • That is the size of difference one expects between two readings of the same sheet. So for M1 on your i1Pro 3, ChromIQ and i1Profiler agree.
  • It is one instrument and one paper, and it says nothing yet about M0 and M2 saved by the new option in 4.3.41. If you ever measure the sheet again with that option on, the three files would complete the picture. No hurry.
We would still like the two ChromIQ .ti3 files as a .zip, so that we can repeat the comparison here and keep it as a test.
About the layout of the turned chart
You are right that it reads oddly: in i1Profiler the columns run from L down to A, and one ChromIQ sheet becomes two i1Profiler pages. That comes from turning the sheet a quarter turn, so that ChromIQ's strips become i1Profiler's rows. Nothing is measured wrongly because of it, as your comparison shows, but we will look at whether the labels can be made to read naturally. What would you expect to see there: columns A to L from left to right, or ChromIQ's own strip letters and patch numbers?
Back
