Who has the longest running inkjet printer?
over the years i've refilled the MP980's 6 ink carts for a total of 689 refills, most ink carts have only been replaced 2 or 3 times
Maybe you need to stock up on newer cartridges, because I found some of my BCI-6 carts failed in their seems and have now switched to using CLI-42’s for my i9950..
wilko
leeds, UK
Canon Pixma
My oldest printer is a MG6200 which still continues to reject non OEM cartridges but can eventually print with some coaching but I have had to get rid of many canon printers from the days of the ip 3000 and 4000 and following on with the ip4500 up to the IP 4750 and then the IP 7250. What a pile of crap that was . All had print head failures. Still I have saved thousands of pounds refilling cartridges for these printers. Now i remain committed to Canon printers because of the TS700. This is the best standalone printer that Canon has produced, imo with no print head failures in my experience This is the IP4000 reborn. no resetters but refillable ink cartridges readilly available. Grab it while you can if you want a basisic inkjet printer capable of fantastic photo prints.
and duplex printing. Can't see Canon continuing the this printer for long. I also have a G500 for photo prints but my TS700 printers are the best I have ever owned for all round printing
..........the IP 7250. What a pile of crap that was.......
I agree I have also had an iP7250 and the MG5550. The printers of this series were clumsy, flimsy and noisy in my opinion. They also didn't have the rear paper feed so photo paper was loaded from the cassette or paper shelf. This often caused problems. They probably were the worst printers Canon made.
.....Now i remain committed to Canon printers because of the TS700. This is the best standalone printer that Canon has produced, imo with no print head failures in my experience This is the IP4000 reborn......
I agree. It seems the TS series of printers was much improved. I've also had a TS700, bought second hand. It was much more sturdily built than the previous series. Sadly it died from a printhead failure. I also have a TS8350 that works perfectly but also using the PGI-580/CLI-581 cartridges for which no resetter is available. Even the compatible cartridges are more expensive than those compatible with the PGI-570/CLI-571 cartridges.
@The Hat When was the i9950 made? I wonder if it is the oldest Canon inkjet printer still going strong?
jimbo123
USA - NJ
MP830 MP980
looks like the i9950 was introduced in 2004
https://www.ephotozine.com/article/canon-bubble-jet-i9950-a3-printer-introduced-1626
older than my 4 active printers:
- MX700(2007)
- MP980(2008)
- MX870(2010)
- PRO-100(2013)
J
• Active Printers: MX700(2007), MP980(2008), MX870(2010), PRO-100(2013)
• Stored Printers: IP4500, MX860, MX870, MP980
• Past Printers: MP830
• Method: German Durchstich Method
• Ink: Hobbicolors, then OCP, ASPEN, now alternativesupplier.com
• Misc: Squeeze bottles - so much easier than syringes
I don’t really know, and it runs trouble free anytime I start her up, (About every month or so) still on 10 year old (Precision colour inks) from OctoInkjet..
It’s now the only dye ink printer I have left, and I still manage to get covered in ink when refilling...:th:lol:
Glomgold
MG6650, MP610
MP610, one printhead replacement after five years, the small black isn't perfect on the nozzle check, but it doesn't show on prints. Decided to leave it alone, tried various things several years ago.
Have been using unoriginal cartridges.
I think the MP610 was introduced around 2007, so it is almost 20 year old. IMO the PGI-5/CLI-8 series of printers were the best Canon made for home use.
donaldolsen
United States
Canon i560
I'll start.
I still use a Canon MP730 (purchased new in 2003). Thanx to The Hat for providing two new print heads (I still have one spare)! It is used daily for at least a handful of primarily household printing tasks.
I have changed the print head once, changed/cleaned the "diapers" twice (THAT"S a real chore), and have used refill inks in the same carts over and over again (although I've had one cart fail and required replacement).
I estimate it has run through several dozen of reams of plain paper. I use "quite mode" exclusively, to reduce print head duty (it prints slower in that mode).
The expense of home printing for me is a function of paper cost, not the ink.
It still prints under Windows 10 (don't know about Windows 11 yet). The fax function still works, but scanning seems to be lost under Windows 10.
Anyone else still running one so old (21 YEARS)?
That is seriously remarkable for a 21 years old printer. Mnay newer models do not hold out this long at all. It certainly shows that taking good care and using refill made all the difference.
