Who has the longest running inkjet printer?
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
I'll start.
I still use a Canon MP730 (purchased new in 2003). Thanx to The Hat for providing two new print heads (I still have one spare)! It is used daily for at least a handful of primarily household printing tasks.
I have changed the print head once, changed/cleaned the "diapers" twice (THAT"S a real chore), and have used refill inks in the same carts over and over again (although I've had one cart fail and required replacement).
I estimate it has run through several dozen of reams of plain paper. I use "quite mode" exclusively, to reduce print head duty (it prints slower in that mode).
The expense of home printing for me is a function of paper cost, not the ink.
It still prints under Windows 10 (don't know about Windows 11 yet). The fax function still works, but scanning seems to be lost under Windows 10.
Anyone else still running one so old (21 YEARS)?
Nice to hear they went to a good home.. :thumbsup
I have a 2010 i9950 A3 Canon, but I don’t know how long more it’s going to last because I gave away my last print head to @Redbrickman for his Pro 9000, his printer was a lot newer than mine.. It sort of made sense at the time..
I also have a Brother1240 laser printer since 2000, this one was the very first USB Brother laser made, it can also be connected by parallel cable ? as well, but these printers tend to last for ever.. I also have a 2001 Samsung laser..
My oldest printer is an HP DJ930 of the Windows 98 era. It is not in daily use but fully functional. It works with Windows 10 without problems.
jimbo123
USA - NJ
MP830 MP980
can't beat 2003, but have a few old ones that are still printing fine, also easy to refill
- MX700(2007)
- MP980(2008)
- MX870(2010)
- PRO-100(2013)
also have several similar-aged backups stored as well. many were purchased as canon refurbished bought for $59, $69, as low as $35 for the 980s
J
• Active Printers: MX700(2007), MP980(2008), MX870(2010), PRO-100(2013)
• Stored Printers: IP4500, MX700, MX860, MX870, MP980
• Past Printers: MP830
• Method: German Durchstich Method
• Ink: Hobbicolors, then OCP, now ASPEN
• Misc: Squeeze bottles - so much easier than syringes
Printer hoarding was already a subject in the forum quite some time ago
https://www.printerknowledge.com/threads/introducing-hansteis.11138/post-93654
I dumped my 20 year old Epson Pro 7600 about half a year ago and have an Epson SC-T3100X on order which is supposed to be delivered just before Christmas.
It could not just be of interest looking for the oldest printer but that printer which runs the most pages with the first printhead, I'm doing 60 947 pages with an L805.
My L805 printer - 6 inks dye - got a defect with the paper transport mechanism, strange noise, whirring gear wheels, it is quite difficult to get to the mechanics, the tooth wheels. I decided to replace this printer with a new L805, the unit started up Dec 2021 and printed 72 000 pages since then, which includes about 10 000 sheets A4 with images of sports and social events. I just had to replace the waste bin once, and the printer was barely doing any cleaning activities; the nozzle check print looks o.k.; an Epson printer just needs to print, and ink related problems barely come up.
W. Fisher
Epsons, Canons, Brother.
I have a couple of Epson Stylus Pro 3880s from around 2010 and both are still running. Got two as I wanted to try the piezography B&W ink set in one from the start, but not happy with the results and tedious calibration mess so it became a refillable dye ink printer.
One took a major tear down to replace the print head carriage due to a curled paper strike. Part out of China was about $75, but the lengthy repair took me 2-3 days to get it back working again. I also have a couple of the black ink change valves on standby, but since I do not change between those two inks anymore (I always use Photo Black now and no Matte Black.) I haven't had to replace them...yet.
My default printer is a Canon MP990 that was installed for the first time in May 25 2010, almost 16 years ago.
A few months ago I had a B200 error, but luckily I had an MG6250 that uses the same printhead which was a little worn in the photo black nozzles, but usable. I installed the printhead in the MP990 which was operational again.
Normally you shouldn't switch printheads between printers, as there is a risk that the defective printhead damaged the logic board and a damaged logic board can damage a new printhead. The reason I moved the printhead instead of using the MG6250 is that the MG6250 has a CIS scanner and the MP990 has the much better CCD scanner. Luckily no damage was done to the MP990, so I gambled and won.
jimbo123
USA - NJ
MP830 MP980
peter
congrats on the 16 year run and the successful print head move. the MP990 was built to last and you have proven that.
i have it's predecessor an MP980 still printing. back in 2010 i caught a deal on refurbished MP980's for $36 each. i grabbed 5 of them, gave a few away and am down to 1 MP980 and 1 print head still stored away for future use.
over the years i've refilled the MP980's 6 ink carts for a total of 689 refills, most ink carts have only been replaced 2 or 3 times
J
• Stored Printers: IP4500, MX860, MX870, MP980
• Ink: Hobbicolors, then OCP, ASPEN, now alternativesupplier.com
