How to generate a simple RGB printer profile using ArgyllCMS and the CR30 colorimeter/spectrophotometer
ohtoulouz
Canon Pro-300
Thanks @pharmacist,
I have another question: I have seen patch targets that are in portrait and others in landscape. When reading the patches with CR30, which direction shall I follow? My understanding is that patches must be read:
1) All A (column or line) from 1 to the last number
2) Then all B (column or line) from 1 to the last number
And so on up to the last Letter (column or line) from 1 to the last number.
Is it OK, or shall I read the patches in column, whatever the orientation (which seems weird)?
Thanks for your help !
Pierre
Epatcola
various
Hello guys,
Searching for printer calibration, I found this (very interesting) thread yesterday and I think that I have understood the whole process. However, would you be so kind to confirm my understanding:
Assuming you use windows you would be better off using the powershell script here and also check my post which details how to generate your own targets and generate .ti3 files from the command line with an awk script.
edmundronald
Epson 3880
- I think the latest Argyll has a bug and it may be better to regress a bit.
- why can't someone post the target files directly if you are all using the same ones? They're just text and a tiff, no?
Edmund
Epatcola
various
A bit more information on the bug would be interesting.
We are not all using the same ones. The required patch size depends on if you are using a guide and its pitch. Then you have paper size to choose then how many patches you can be bothered to measure and how many you want to allocate to greys.
I posted a few batch files to generate targets. They are not hard to modify.
edmundronald
Epson 3880
You will be welcome on the Argyllcms list, it's doubtless of interest to you! Here is where the bug descripton starts in this month's archive, and a few posts down there's a workaround. Myself I always forget everything so I would regress a bit to an older version, to avoid making a mistake the next time I run the code, but then I'm just old and was never smart.
https://www.freelists.org/post/argy...L-INK-LIMIT-if-neither-l-nor-c-flags-are-used
A lot of people aren't programmers and it's very often helpful to them to post actual data files. Seriously. Also, example files show you what you are doing when you sit down to mod a script.
Edmund
Epatcola
various
The batch files have 2 lines. One to run targen and the second to run printarg. You don't need to be a programmer to edit command line parameters in a batch file or to run one. It took 27 lines in the readme to document all you need to know about target generation.
edmundronald
Epson 3880
To get back to argyll, do you think that in light of the following, setting the ink limit of something like 310 might be preferable in your use of colprof?
https://www.freelists.org/post/argy...INK-LIMIT-if-neither-l-nor-c-flags-are-used,4
Btw, I usually find warmer to be better, if there is no perfect choice. I had a look with the thingy on the Mac that shows you color values for pixels, and it's amazing how one notices skin tone tint changes of a few delta e which would go unnoticed in strong solid colors.
Epatcola
various
The ti3 generation script I wrote for the CR30 doesn't write an ink limit so it is a non-issue for that usage.
Scanning the list you linked it does look like if the ti3 contains an ink limit forcing it to 310 with a colprof parameter is a work around for the problem.
