Canon imageprograf pro-1000 | Error 1206 "maintenance cover is open" but its closed
tito1943
Canon pro 1000
Hi all, I wonder if anyone's managed to overcome this issue or any advice to solve it?
So the support code '1206' says "the maintenance cover is open, close the maintenance cover & select ok", but the problem is that the maintenance cover is NOT open, its fully closed. This error message just won't go away, it pops up as soon as I turn the printer on (even before agitating ink etc) and I just can't seem to get rid of the message. I've run some searches online but surprisingly I can't find much info with this error message. I thought it would be more common.
The problem started when inserting a new maintenance tank after the previous one was full, so I replaced it with a brand new mc-20 canon maintenance tank but since then this error message won't go away.
I've contacted canon & they replied saying: 1. Inspect the locking tab, 2. Reinsert the maintenance cartridge firmly, 3. Hold the cover closed during startup, 4. Check for obstructions, 5. Make sure you're using a Canon-branded maintenance cartridge. I've followed all these steps but this error message has never budged.
If anyone has any help/advice to solve this issue, it would be much appreciated 🙏 I love this printer & it would be such a shame if I can't use it just because of a silly error message saying the door is open when it's not. Thanks for your time. Damien
tito1943
Canon pro 1000
no one has had this issue? any help would be much appreciated. Thanks you 🙏
Your printer is caught in an error loop, try to create a deliberate error that you know with trigger a response from the printer and so break the cycle, or try to short out the affected sensor.. ?
tito1943
Canon pro 1000
Ah thanks for the suggestion 🙏 I'm willing to try anything because since that error message popped up a few weeks ago, this printer is utterly useless & its a real shame.
I've never heard of a printer error loop so thank you for suggesting, I will go down a rabbit hole learning about this now. But I've just tried to see if I can get a different error to pop up instead by opening the front door where inks are, removing some ink cartridges, opening door where you can see print head etc, and I've also tried them all at the same time, then turned the printer off & when I turn it back on again the first thing that pops up is the same error code 1206 "the maintenance cover is open" even though all these other doors are open also. So I'll continue trying to create a deliberate error.
And you mentioned to try & short out the affected sensor, I'm unfamiliar with this, but it gives me a new lead to work with so I'll research that also. Thanks again for these suggestions mate 🙏 truly much appreciated
tito1943
Canon pro 1000
Does anyone know if this is the sensor (in the maintenance tank cavity)? chatgpt reckons this is the sensor but I'm a bit sceptical because I've poked/prodded it etc & it just feels like a little piece of plastic.
Thank you 🙏
You could also try and insert the old maintenance tank again, that might solve your problem..
tito1943
Canon pro 1000
I've tried that unfortunately, the old one was full, so I replaced it with a brand new MC-20 maintenance cartridge, that's when this problem begun, but I had another brand new maintenance cartridge (2nd one) that I tried to make sure it wasn't just this maintenance cartridge that's the issue, but nah, the 2nd new one didn't work also & this error message still pops up.
I've run some google searches etc & weirdly I can barely find any information on this issue, actually I think I only found 1 report on the canon forum where someone had the same error code where it says the maintenance cover is open when its not, on that thread the poster said they didn't find a solution so the printer was binned. It would be a crying shame to throw this printer away just because this error message says a bloody door is open when its not.
Yes I know the old maintenance cartridge was full, but putting that one back in and then powering on the printer may get a difference response. What your trying to achieve is to get the printer to recognise a completely different error, or no error at all..
If you don’t get the error code 1206, then just replace the full cart with a new one without powering off the printer..
I have to ask at this point:- is the new maintenance cartridge an official OEM Canon replacement or a third party one, because that can make all the difference, again with this type of error it may require an OEM chipped cart..
Remember these printers have an AI chip inside them and you need to play a different game to circumvent the response it requires, by giving it what it expects, nothing else will work.. I reckon at this point the error code 1206 is erroneous and doesn’t actually exist (Bogus) in their data base..
tito1943
Canon pro 1000
Thanks for all the help & suggestions The Hat 🙏 I think this last message was spot on.
I have some good news 😁 yesterday the printer rose like a phoenix from the ashes, the error message buggered off & I managed to print something, I still don't really know how or why. I'm still a little shocked to be honest.
This printer hasn't worked since the day I come home from holidays which is two days short of 4 weeks, that 1206 error popped up after changing the maintenance tank & that error hasn't gone away since. Oh these were official Canon OEM maintenance tanks btw. As I said in previous posts, I've tried many different things that Canon support suggested (but didn't work) but I just couldn't find any search results for this error code except for 1 person, which I found really odd.
I almost give up hope, I spent a few days fiddling around with the maintenance tank, but there's not much to actually fiddle around with in there, and I couldn't find anyone else who's had this problem except that 1 person who had that error & Canon told them the printer is dead so they should dispose of it & Canon would give them a 10% discount on a brand new printer, but I made this thread & I'm really thankful you replied The Hat 😊 you suggested new avenues that I could look down such as error loop & affected sensor, so this week with your help & posting all day on chatgpt, I've been back on the case trying to fix this printer after giving up on it for about 3 weeks.
But to make a long story short because I'm bad at keeping things concise. So yesterday I was fiddling around with the printer, trying to locate the sensor in the maintenance chamber, chatgpt sent me on a wild goose chase multiple times 😆 I done enough fiddling around with the printer for the day, my brain was fried, I figured I would try again today.
But last night as I was about to go to sleep, I turned my bedroom light off but light was coming from the printers operational panel, which was strange because for the last close to 4 weeks, all that's been showing is the orange triangle (issue/error sign), then if I press ok that error message pops up, then if I don't touch the printer for a few minutes the panel goes dark & I'm left with just the orange triangle light. But last night the operational panel was lit up, same message "maintenance door cover is open", but something really strange, it was the same error message but this time it had a slightly different error number, so for nearly 4 weeks its shown "1206" but this time the number was "1209", so I pressed ok like I've done about a thousand times in the last 4 weeks, but this time the error message went away & I could hear some moving parts in the printer, the first signs of life in a month, so at this stage I thought back to your first message about creating a deliberate error to try & break the loop, so I opened the print head door, the door where the ink cartridges go, removed a few ink cartridges, basically in a frenzy, and I think I turned the printer off when it started agitating ink also, I had no real plan as I'm sure you can tell 🤣 the next error message that popped up was one of the inks might have run out, again I was just happy to have a different error message, so I whapped a new ink in, it took a while agitating ink etc, but then it looked all good to go, no error message anymore, so I tested it by printing out a small A4 print, thinking that maybe that error message would pop back up, but it never did, the print came out fine & its like my printer has come back from the dead, I'm both really happy & confused.
I wish I could offer some real info/advice incase someone else runs in to this apparently super rare error code, I wish I knew a fix, but I have absolutely no idea how this printer came back to life. But again I would like to thank you The Hat for responding to my message, without that I probably wouldn't have bothered fiddling around with it anymore, your message give me a bit of hope, some new things I could try implementing, I already had another printer in my basket, I was that close to buying a new one & it would have broke my heart to get rid of this printer just because of that silly error code. So thanks for all the help & advice. Its been much appreciated 🙏 Very best wishes The Hat 😊
Now that’s the type of news I like to hear, congratulations to your persistence and not giving up on the old girl, now go and enjoy her as much as you like, because you deserve a medal for your patients, good things come to those that wait they say.. :thumbsup
